I want to change all the oil in my auto box and clean the filter.
I know I drop the gearbox sump to get to the filter and change the oil in the sump, I can change the oil in the Torque converter by disconecting the pipes from the radiator, cranking the engine and using 2 buckets, no problem.
What I cant work out is what order to do it?
If I drop the sump clean the filter, re-fit the sump, re-fill, then do the radiator bit, will I then pump out the new oil in the sump as well when I change the oil in the Torque converter?
Is there a correct order?
Thanks
Thanks
have to be to fill up these beasts with diesel
