rear diff?
  • rear diff?
    got a lot of whine from the rear diff? when its under load when i dip the clutch it stops plus its leaking oil at the prop end
    ps its the lsd type any ideas what it could be?
    Leaking oil at the end is probably the inner bearing seal, fairly easy job to replace. Dunno about the whine though, could it be the bearing?
    Paul </Slugsie>
    Immortal.so far!
      its been sugested its the pinion bearing?
        That sounds likely to me.
          i can let you
          i can let you have my spare back diff pm or e mail me @
          jeffandang@tiscali.co.uk
          its out of a 2.4 .n out of a k plate its just sitting in my shed
          i was holding on to it as a spare but if you want it you can get it picked up or as you are in the north east you could drive up and get it an if you want i can help you fit it its up to you
          S S R G is the only way to surf
          scottish mud club member kerelawsurf
