pulling
  • pulling
    My truck pulls to the left.
    I have had the tracking done also changed the two front tyers around. It stills pulls.
    Live the dream.......
    Most likely a sticking piston in the brake caliper, it always seems to be the left side for some reason. Previous owners let the pads wear down so much that the piston/s comes out further, corrosion takes old, and the piston can't retract properly.
      one arm longer than the other lol
        Agree with Mr B Whacker. I had the problem too. A clean up of brake caliper pistons sorted it.
        However, they do tend to pull one way or t'other, especially if you have larger than usual tyres.
