Hi Guys
I have a leak, not a large one, but one I want to address none the less....
Its where the flange goes into the rear diff.... (if thats not technically accurate, the bit the prop shaft bolts onto that then goes into the diff... flange?)
It looks like thats leaking... I presume its just a seal thats gone....
Is this a simple job?
Does anyone know if the bolts are torqued up and if so what torque settings I need to know as I don't have a manual yet...
Any other info on the job would be well appreciated.
Thanks guys in advance.
CM
CM
