Help! No bolts in starter Motor?
    If i remember rightly then i just moved the fuel filter housing to be able to get to the top bolt.Theres not a great deal of room but it can be done from above
    scrap that i just remembered i used long extension bars and got them both from underneath fiddly but easier then the top
      Don't know if you've got there already but - copy this
      http://toyotasurf.asn.au/techsite/starter.htm
      I did and its a good write up.
      Make up the long wrench exactly as he says and it'll work - you have to thread it up from under the car and through the frame.
      Take the NS wheel off - much easier.
      Coz of my body lift, I was able to wriggle the motor out and down past the frame. If you are coming up past the fuel lines, try and attach a length of rope to help pull the motor up - its very difficult otherwise.
      Oh, and quite the stinkingest job ever!
        Somethink like I said in me first post, No 2 forgot they nut n bolt tho ....Cos
        it's at least 2 years since I done mine n no Body lift !!!!
        note to self: 2" body lift !! for next time ..... aahhh
        There's always a Payback ..... Ya just never see it Comin !!!!
        Buncefield Burner
