Rear window mech, how much?
  • Rear window mech, how much?
    mine is showing usual signs of wear in the worm drive and was wondering how much this is gonna cost me?
    someone said the NS rear motor is a straight swap but had a good look and motor unit is hard fixed to the window mech on the rear door and tailgate so a bit confused by this...
    Toot! Toot!
    If you want i can show ya how to get em out, 3 x 10mm bolts and itll come right out easy mate, theyre hidden behind. Also i can phone stormforce and he could send one up if you need it. Not sure if i have one actually.
    Is it just motor you need or is it the works aswell?
    Without Surf And Unhappy
      well the teeth on the works look fine and the window runs up straight, expect it's just the worm drive as the window goes up a bit, stops, up a bit, stops etc but the motor can be heard running all the time
      Toot! Toot!
        Do you have a welder?????? Oh sorry and its 8 mm spanner oops
          You'll need to do this then.....
          http://forums.bauchan.org/portal/viewarticles.php?rid=0
