Wheel size / wind up
  • Wheel size / wind up
    Hi folks i was reading athread about using different size tyres/ wheels im running 265/75/16 on the fronts and 31/10.5/15 on the rear .
    Will this cause axle wind up??
    Scottish mud club
    Only if you use 4wd.
      Enter both sizes in the compare tyre sizes section and click compare. There's a little over 2% difference in diameter.
      http://www.1010tires.com/TireSizeCalculator.asp
      Nev
        Ooops been off roading twice on these tyres!
        there is a slight grinding/rubbing noise coming from the rear when i reverse mostly.
        Have i pumped the truck any remedies??
        Scottish mud club
          If you off-roaded in slippy muddy stuff, then it won't matter much. Would be a good idea to get all one size on if you can though - unless you want the dragster look.
          Paul </Slugsie>
          Immortal.so far!
