good morning all does £65.00 sound about right to fit millners 20% stronger springs chap says its one hour plus job many thanks
new springs
It's a very easy job to do, a quick search will turn up the steps for fitting LandCruiser springs which is the same process. If you can wield a spanner then do the job yourself.Originally posted by BIG GENERAL View Postgood morning all does £65.00 sound about right to fit millners 20% stronger springs chap says its one hour plus job many thanks
If not, then about an hour sounds right, but £65 for an hours work? I'm in the wrong job.
Paul </Slugsie>
Immortal.so far!
a job well worth doing, did mine 2 weeks ago, the ride and look much improved. on hard setting its like a go kart now. easy job, takes longer to get the tools out and clear up than doing the springs!!!Originally posted by BIG GENERAL View Postgood morning all does £65.00 sound about right to fit millners 20% stronger springs chap says its one hour plus job many thanks
some pics of us fitting springs on sunday.
a couple of hours.
http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=42253Alan
