Fitted LC spings today went to adjust bars to suit. Driver side no bother.
Passenger side the cam type locator that sits under the 22mm bolt head is turning with it. I have tried heat, all I can think to do now is tack weld the locator to the bracket it sits in. Hopefully then I can turn the 22mm bolt and break it's love affair wih this cam shaped locator.
Anyone else faced this issue and what did you do
