Where can I get Rear spring Spacers?
  • Where can I get Rear spring Spacers?
    I want ot fit milners 20% rear springs into my 2nd gen surf,
    I also want to lift the rear 1.5 to 2 inches.
    Where can I buy spring spacers in the UK?
    Any hints on fitting, problems?
    These will give you 2" lift without spacers
    http://www.roughtrax4x4.com/?doc=16&cid=155&vid=376
    And these will give 3" lift without spacers
    http://www.milneroffroad.com/HDJ80.HTM
    Front Coil Spring (pair) 8/1991 - 1998
    003783
    44.00
    Brian
      Thanks joshie,
      I have been looking at some posts here, are those Roughtrax springs the ones that people say seem to compress after a while?
      Thats why I thought the Milner ones with spacers would give me the lift and would hold their height long term.
      Or are they different?
        i had the springs with spacers and after 8 months were still same height
        Without Surf And Unhappy
          Originally posted by walkabout View Post
          Thanks joshie,
          Ive got the new Roughtrax +2" springs an 2" spacers from 4crawler.
          They have settled about 0.5" which is fine! They are a good spring, teamed up with some ES9000's the handling is still pretty good!
          Was that the new roughtrax ones mate? the swedish ones?
            Thanks joshie,
            Thats old news, Roughtrax, LA Supertrux and me havn't used sold those old Procomp springs in ages.
            Springs do settle in time, especially if you use them heavily.
            (I have spacers here if you still want them)
              I know its been a while since you posted this, but dont suppose you still have those spring spacers! I could do with a pair?? cheers
