Anyone know if the gearbox input shaft from the gearbox off an 18R petrol engine is the same length as a 2LT diesel one?
Petrol Pickup Gearbox (Urgent!)
the 18r was in the mk 1 & 2 hilux, i would say both them engines used the same box, the later diesel was a 2.2Originally posted by ElvzAnyone know if the gearbox input shaft from the gearbox off an 18R petrol engine is the same length as a 2LT diesel one?[font=Times New Roman][size=3]
[size=5][/size]
18r imput shaft
gemini you got that a bit wrong 18 r engine was fitted in the mk1 hilux and on y reg 1983 they did do a face lift with square headlamps for one year there was some 2.2 diesel mk1 pickups about that seem to of been imported through ireland they then made the mk2 hilux in 1984 with 3y 2.o litre petrol engine and 2.4 diesel then about 1986 87 they put a 4y 2.2 petrol engine then came the mark 3 hilux pickup in 1989 and so on. the mk1 had a 4speed gbox execpt diesel that had a 5speed box but was diferent to the mk2 box (very rare Box) the mk 2 was five speed
the 2l petrol that was fitted in the mk2 was the 18r engineOriginally posted by gerry manngemini you got that a bit wrong 18 r engine was fitted in the mk1 hilux and on y reg 1983 they did do a face lift with square headlamps for one year there was some 2.2 diesel mk1 pickups about that seem to of been imported through ireland they then made the mk2 hilux in 1984 with 3y 2.o litre petrol engine and 2.4 diesel then about 1986 87 they put a 4y 2.2 petrol engine then came the mark 3 hilux pickup in 1989 and so on. the mk1 had a 4speed gbox execpt diesel that had a 5speed box but was diferent to the mk2 box (very rare Box) the mk 2 was five speed[font=Times New Roman][size=3]
[size=5][/size]
My MK1 had a 18R, never saw anything but 2.2's or 2.4 2L Diesels in MK2's.Originally posted by geminithe 2l petrol that was fitted in the mk2 was the 18r engine
But it don't help Elvz though
So don't worry.
Only got 5 speed manual to measure, but 18r's only used 4 speed, so may be different. (plus its up the lane in the dark and wet, and I'm cleaned up, showered and not going out again!!!
my mk 2 had an 18r engine thats how i knowOriginally posted by TonyNMy MK1 had a 18R, never saw anything but 2.2's or 2.4 2L Diesels in MK2's.
So don't worry.
[size=5][/size]
why dont you just answer elvz question then, it was a early mk2 hilux on an A plate brand new from toyota with an 18r engine in it, i have a pic somewhere ill post it up, my mate had a left hand drive same as mine but on a y plate, would that have come from ireland, that was the 18r as wellOriginally posted by gerry mannmust have been a mk1 then 4 speed gearbox 18r wont go on to a mk2 box
mk1 1978- 1984
mk2 1984 -1988
mk3 1989-1996
ps have been working on hiluxs and fourrunners and surfs fo 12 years now!
rebuilt more than i care to rememberLast edited by gemini; 14 March 2004, 23:13.[font=Times New Roman][size=3]
[size=5][/size]
elvz, its looking like it wont fitOriginally posted by geminiwhy dont you just answer elvz question then, it was a early mk2 hilux on an A plate brand new from toyota with an 18r engine in it, i have a pic somewhere ill post it up, my mate had a left hand drive same as mine but on a y plate, would that have come from ireland, that was the 18r as well[font=Times New Roman][size=3]
[size=5][/size]
18 r engines
have had a couple of left hookers in to convert from left hand drive to righthand drive. had one in with a 22r engine with the short bed on it .not a cut down one. there was a few mk1 face lifts on A plates diamond shaped front grill patern and square headlamps cromed door handles and the wing mirrors were up on 2 inch stalkes and of a square shape. front side lamps were built into headlamp besel slightly curved , long amber side repeter indicaters.Last edited by gerry mann; 14 March 2004, 23:29.
