alloy wheel help
  • alloy wheel help
    hi, found these on ebay, will they fit my 1994 4runner ?
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=010
    they should fit ok as they are a toyota wheel
      i realise it is probably a stupid question but i just want to make sure before i bid incase i end up with wheels that dont fit after ive paid £50 postage !
        is the seller bunkle from this site ????
          If Maldon is in Essex then yes it is i would of thought.Worth sending him an email and asking and see what he wants for them to end the auction early
            done
              BUT. Beware though m8. As the it says in the box that thr rim width is six inches. Most people run seven, eight or ten inch wide rims.
                You will regret buying 6" rims.
                Nev
                  I dont wanna pi$$ on your or the seller guys fire BUT
                  I know you said you wanna run 33's soon.
                  Well if you want the big wide bad boys then you just CANT put them on a 6" wide rim! No way!
                  You'll want at least a 8" wide rim. Plus they look like they have a very small offset - they will be hiding in your wheel arches an look...feminine.
                  In general the auction is good value for money! But id say more suited to a hilux pickup or surf with no arches.
                    thanks again guys, i will be on 33s soon and i do want that wide look so what about these !! http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA:IT&ih=018
                      might be a bit too extreme mate.
                      To run those you would need a HUUUUGE lift.
                      like 4" suspension (which aint cheap) and a 3" body lift an even then you might have clearance issues.
                      http://www.supertrux.com/acatalog/Steel_Wheels.html
                      www.silverline4x4.com
                      Both those places do 15"x10" rims. Which is what you want for the nice wide stance.
