Originally posted by smiffy
You'll be fine, go careful with brake pipe connections, they often sieze in. If you need mole grips to get them undone it'll ruin the hex of the nut. Its not the end of the world, but you'll have to do them up again with the grips and make sure they don't leak.
Bleeding them is easy, assistant presses down pedal and holds, you open bleed nipple, pedal goes to the floor, you close bleed nipple, they lift off the pedal, repeat till it stops spitting air out.
After you've refixed everything and bled it, get someone to stomp hard on the brakes and hold them down and check for leaks around the hose and bleed nipple connections.
