Starter Turnin Very Slowly
  • Starter Turnin Very Slowly
    Is this due to flat batt? Or should i check something else too?
    I think it may be a battery problem though.
    Without Surf And Unhappy
    bad earth, chassis to battery or engine to chassis maybe
      Thanks mate, where might one look for said earths? I spose i could findem wiv a good look
        not sure about the engine to chassis one but on most cars its a strap some where close to the starter or alternator
        the battery to chassis is easy negative terminal on battery has i wire going to the inner wing, if you offroad a lot or theres rust around the points of contact you may have to undo the connections and clean them up, lubricate with vaseline or similar and reconnect.
          if it looks like this under the hood then.......................... .......................worry
            Ok thankyou buddy will have a look tommos, when i finish off my body lift.
            Thanks for the info.
              Yeah, I'd be worried with that - someone's nicked the right hand battery and IT'S TOO CLEAN
              Trev
                Have you checked the oil
                www.cnpbetterhomes.co.uk
                  Rad cap?
                    I would worry if I were you.........yer dinners missing!!
                    Tony
                      Quick Battery Check
                      Put the headlights on then try and start the engine.
                      If the lights go realy dim then it is most probably a battery problem as in FLAT
                      or BU**GR*D.
                      Not the most technical way but quick and easy.
                      The other (technical) way is a voltmeter across the +and - battery terminals and abserve/look at the voltage when cranking the engine over this will tell all
                      Regards.
                      Mike
                        Twas a bad earth to the wing, new nut and bolt has cured it, thanks fellas.
                          Nice cheap solution
                            Originally posted by Tiger
                            Nice cheap solution
                            Yeah did that after checkin the oil
                              happy to help, thank god it was a cheap fix
