i am getting a knock from the off side front wheel when going foreward on full lock not in reverse. its my first surf so any ideas thanks
knock on full lock
Originally posted by sdgarmani have started getting a knock when i go foreward on full lock,not in reverse,its coming from the front offside wheel when on full right lock.anyone have any ideas
Slap some grease on your steering stops!!! I'll look out a pic later.. but try a search!!!
Linda
www.4x4toys.co.uk
Sounds horrendous when they are dry but a bit of grease shd cure it!Originally posted by sdgarmanthanks i have seen the pics,thought it might have been the drive shaft.its my first surf i came from landrovers
Linda
www.4x4toys.co.uk
Is it a regular knock / thump or a clickety click as the wheel goes round ? The second noise my be a CV joint..... something Tony's big truck knows lots about eh Tony ??[center][font=Microsoft Sans Serif][size=7][color=magenta][u][b][img]http://www.gifs.net/animate/hipgrl12.gif[/img][/b][/u][/color][/size] [img]http://www.gifs.net/animate/hipmn1.gif[/img][/font][/center][center][img]http://homepage.ntlworld.com/jim_ashton/shyAV5.jpg[/img][/center][center][b][color=#ff00ff][size=7][u]E[/u][/size][u][size=5]ms [/size][size=5]&[/size][size=7] J[/size][size=5]im[/size][/u][/color][/b][/center]
And his little truck....Originally posted by Ems and JimIs it a regular knock / thump or a clickety click as the wheel goes round ? The second noise my be a CV joint..... something Tony's big truck knows lots about eh Tony ??
Linda
www.4x4toys.co.uk
steering stops should have a little black plastic cover on the ends they have probably worn through or fallen off either replace them they only push on or do as everyone says and whack a blob of grease on the stopOriginally posted by sdgarmani am getting a knock from the off side front wheel when going foreward on full lock not in reverse. its my first surf so any ideas thanks
ends
knocking? - more like a mad mad hammering with a scaffold pole!
hmmm..... is my problem the same?
on full lock, at slow speed, dunk! dunk! dunk! very loud and scared the living sh*t out of me!!!! sounded like a big bag of scaffold poles being shaken under the offside front.
off to locate the pictures so i can see where to grease meself up...If you're gonna be a bear... be a Grizzly.
http://www.hiluxsurf.co.uk/forums/showthread.php?t=651
