i'm getting the dreaded clicking sound coming from my starter, where i have to repeatedly turn the ignition rapidly to get the starter to fire
my first thought is that the contacts are gone in the starter but i had these replaced about 9 months ago when i was having the same symptoms and it solved the problem
Could the contacts be worn ALREADY?
the only difference between the last time i had the clicking sound and now is that before the clicking would occur at every start but this time the clicking only occurs in the morning at first start...it does not occur i the evening after work when the engine would also be cold
any thoughts greatly appreciated
