hi does anyone know if a 2.4 auto rear axel or diff will fit a 3.0td manual?the 3.0 is a LSD not sure on the 2.4,but both 2nd gen models,cheers
2.4 diff into 3.0
check the axle codes off the vin plate, make sure they are the same ratio.
More info here http://toyota.off-road.com/toyota/Ax...tegoryId=11290=========
=SOLD UP!=
Generally speaking you can swap them between the 2.4 and the 3.0. But you'll also need to change the front diff as the 2.4 and 3.0 have different gear ratios.
However, I'm not sure if a non LSD diff will fit in a LSD carrier (or the other way round) as I think they are slightly different. In which case you'll want to do a complete axle swap rather than just the diff.Paul </Slugsie>
Immortal.so far!
