Hi Everybody
I have a 2.4 d hilux on a 91, I have had it for 5 years, it was fine for 3 years then of course the head cracked so i replaced it.
It was then fine for another 12 months then it started overheating when it was put underload - which it still does.
I have changed the thermostat and cap, I have pressure tested the water system, - all fine, the test kit takes 2 hours to depressurise. I have tested the water for oil contamination.
It doesnt lose any oil other than usual burn and there is no water in the oil.
Now I am completley stuck.
It pressurises and releases in to the expansion tank, so needs toping up every 3 days.
Any Ideas
Thanks
Any Ideas
Thanks
