The white smoke appears after about 2min of startup. You can feel it miss then the white smoke will follow. It will do this occasionally untill the engine warms up. It starts good, just think it is strange that the smoke occurs after some time. Any suggestions?
White Smoke/Missing 2min after startup
Cylinder head gasket. Sounds like you have coolent leaking in to the engine as the engine warm up,it is burning it away. Are you having to top the rad up? Are you sure its white smoke and not grey? how long does it smoke for? Have you tried some fuel treatment it may just be a sticing injectorOriginally posted by dudewurtisThe white smoke appears after about 2min of startup. You can feel it miss then the white smoke will follow. It will do this occasionally untill the engine warms up. It starts good, just think it is strange that the smoke occurs after some time. Any suggestions?Last edited by charvell; 31 August 2007, 07:13.SWIFT AND BOLD
