It seems my rear axle has decided to start leaking as in the pics does anyne know what the problem might be , job size , any info? help , it appears to be coming from the top n/s of what I think is called the pinion casing and a small amount at the front of the casing where it links to the driveshaft, also there is a small nut with some sort of casing on top of the axle just of centre what is this ting???
cheers wade.
For some reason i cannot upload the pics!!
cheers wade.
