new diff and gearbox questions.
  • new diff and gearbox questions.
    ok, i have a post up on the buchan forum, but thought that most of you guys in the know would be back here.
    so my front diff is goosed and jeff's gearbox is goosed.
    i have sourced a guy with a breaker not to far away,
    so here comes the questions,,,
    1,, the breaker is a 3.0 4 runner, so will the gearbox fit jeff's 2.4 surf?
    2,, whats the chances of the diff codes matching my surf?
    again many thanks for the help, i'd be goosed without this forum
    cheers scotty
    cheers scotty
    I read that the 3.0 & 2.4 have different diff ratios, so you might get away with changing front and rear, but not just the front.Vin plate will have axle code on.
    As for the gearbox, check the transmission code on the vin plate for code as that may help determine if it will fit, unless one of the more knowledgable surfers gets in first.
    Rob
    Still working for the man!
      the vin code mine starts ln 130 and
      the vin plate code mine starts ln 130 and reads
      model q-ln130-gkmqt
      engine 2l-te
      frame No ln130-7009261
      colour trim
      25t gx 12
      tran/axle
      r151f g145
      plant built a52
      can someone tell me what bit is related to the gear box the bit that says trans/axle r151f or is it g145 and if some one knows what the rest on the vin plate is all about can they post that it all about is would help me lot and i would not look so dum when i am ordering parts thanks
      jeff
      ok i have been on wiki- p web site and found out that i have a r151f gear box but will the 3ltr 4 runner on 1994 plate fit my surf and will it work ok
      S S R G is the only way to surf
      scottish mud club member kerelawsurf
        R151F is the gearbox type and G145 (I don't think it would be an i) is the axle code. Some where on this site is a thread or two which tells you what G145 actually means.
        HTH
        edit: oops i didn't read the last bit of your post!
          Yep, Gearbox is R151F. G145 is the diff ratio and type. G-8" 14 = 4.875 ratio and 5 is 4 pinion LSD. 4Runner gearbox may be the same but I'm not sure. I doubt the diffs will be the same though.
            thanks
            thanks nev
