My Steering Has A Mind Of Its Own
  • My Steering Has A Mind Of Its Own
    MY STEERING HAS A MIND OF ITS OWN. sometimes its like a shopping trolley the front end seems to be all over the place is it
    1) steering
    2)suspension
    3 something else
    1) steering
    2)suspension
    3 something else
    I reckon it's your Idler Arm bushes broken up. Mine is the same, just gotta do the job on mine, probably next week. Other than that could be the Pitman arm or the steering box itself (although they are pretty strong).
    I could be suspension but I think it would need to be pretty bad to cause that effect.
      Have you checked the steering damper,or maybe it's the alcohol.
        it was ok till i took my 16" wheels off & put my original 15" back on.
        also the front end is sitting high with no sag at the back end.
          Did you tighten the wheel nuts correctly???
          Worth a look.
          Also you say it now sits high - has one of your dampers broken (come apart) allowing the front to go to full extension? This could also make it drive all over the place.
          Rich.
            Worth a look.
            Rich.
            dampers as in suspension mmmm i'll have closer look at weekend as my knee is a bit sore still. the wheel nuts are tight
              My drivers side outer cv joint has sprayed grease all over my inner wing how would this contribute to the shopping trolley steering effect
                is the outer cv boot a hard job to do
                  Andy,
                  Are the Idler Arm bushes an easy job to do?
                  Thanks..Rab
                  Rabbie
                  "Blossom" she's a 93 2.4td SSRX & we luv her, cost a fortune but we still luv her
                    Come on guys more input required on this one
                      The CV could have $hit in it, our grey truck did this last week, the CV was locking up as I drove around, pulling the steering the left every revolution of the wheel.
                      Only did it with lots of junk in the back, and the CV was running at a high angle, at normal angles it was OK, boot was ripped and CV full of Devils Pit junk, I squirted oil over the CV and its OK for now.
                      Once the CV is dirty, it'll be fubbarred in the long run. but a regrease and new gaiter will suffice for now.
                        Much appreciated TONY
                          sreering idler arm bushes are worn also outer cv boot split.
                          a nice job for saturday i think
                            Going to be doing my Idler Arm bushes on Thursday (plus rear brake shoes and new glowplugs). Thats if it doesn't snow - I'm getting to old to lie on the ground when it's wet and cold, think I need to get myself a garage thats big enough to fit a Surf in.
                              Mines going into stevos garage on saturday, as i cant do repairs due to my knee. plus i dont like doing these jobs in this weather
