Jack and Bar Location
  • Jack and Bar Location
    I have recently bought my first Surf
    Where is the jack and tools normally kept as I cannot find any.
    Cheers Taz
    Cheers Taz
    Jack & bar is under rear seat, I seem to remember the tools are in one of the side cubby holes.
    Trev
      Cheers - Found It
      No wheel brace though.
      Well can't have everything.
      Taz
        Cheers - Found It
        Taz
        Have you no tool pouch
          All I could find was the jack and bar under the rear left seat.
          The 2 storage ares in the boot space are MT
          Are there any more hidden compartments?
          Taz
            You've got a bar in your Surf? Mine's a double, hic.
            Found the bar but Jack had gone home.
            Jacqueline
              Jacqueline
              Looks like Jack took his pouch and wench with him when he left.
              Taz
                Got a punture whilst out today in the Surf, looks like a farm implement 2 foot length of steel bar about 6mm in diameter with a eyelet at one end & a hook up at the other. Never saw it in the road, went straight into tyre, then round wheelarch several times. Pulled it out & managed to get Surf off main road into side road to change wheel. Got the jack out & extended as quick as I could so that it took the weight as soon as possible. Put the rod in to start to jack it up to remove the wheel but what do you turn it with? It's only got a square on the end, is there supposed to be another piece that goes on so you can turn it? I happened to have a car trailer on the back so I lifted the body up with the jockey wheel on the towbar so there was hardly any weight on the jack which gave me enough to change. But I would have been stuffed if I hadn't have had the trailer.
                Alan...
                  Under the rear seat running along the top of the seat base edge (near the jack) should be 2 1/2' long cranked handle.
                  Mark..........
                  Let taste be the enemy of art!
                    Roughtrax sell the bits that you have'nt found if you need them.
                    Here is a pic of the SURFS standard tool kit.
                      Thanks for that, looks like I haven't got the 2 bits on the top right, 09114 & 09118 if they are the right numbers, are these normally in the tool wrap?
                      Alan...
