just got a surf , finding my way around..... to change headlight bulb do i remove screen wash bottle and battery then just fit bulb....... is it possible to have the rear window motor refurbished anywhere.
headlight and window motor
someone has recently done a write up on refurbishing the motor but you can also use the motor from a corolla celica or hiace van passenger side.You can use a motor from one of the rear doors to put into the tailgate as a temporary measure.Originally posted by riversidejust got a surf , finding my way around..... to change headlight bulb do i remove screen wash bottle and battery then just fit bulb....... is it possible to have the rear window motor refurbished anywhere.
You can use the drivers side motors but you will need to turn them 180 degrees to fit
taking the washer/expansion bottle out is the easiesthttps://www.facebook.com/groups/henpals/
as long as its the passenger side it will go straight in but you may need to change the connection block from the old motor.The drivers side should fit also but just need to be turned to fit.Originally posted by riversidethanks, the corollla or hiace ...any particular widow motorhttps://www.facebook.com/groups/henpals/
Have a chat with supersurf cause he is breaking a surf at the mo and has got the window motorsOriginally posted by riversideIME FILLING OUT A FORM ON find a part, its asking for a year on the corolla celica............. any ideas.....also the hi acehttps://www.facebook.com/groups/henpals/
