I seem to have developed a leak from the n/s rear wheel area. Smells like diff oil, the wheel is still firm with virtually no play so i'm guessing it's a seal rather than the wheel bearing, but i'm thinking i might as well do the wheel bearing at the same time, so is the £29 kit from roughtrax the best bet? and how do i go about changing it? is it a fairly easy job?
http://www.toyotahilux.com/?doc=11&cid=147
btw, i checked the diff breather's and they're fine and not blocked.
