How High??????????????
  • #16
    This is a confusing nightmare.
    Looks like I will be fitting 265/75/16 BFGs
    Which set up is taller
    1) 265/75/16 (As fitted now)
    2) 265/75/15
    3) 31/12.5/16
    4) 31/12.5/15
    Cheers Taz
    • #17
      2) 265/75/15
      3) 31/12.5/16
      4) 31/12.5/15
      Cheers Taz
      265/75/16 is the tallest and 31x12.50r16 is widest.
      You can buy a body lift kit for £85 which will give you the room needed for the 33's BUT your Tjm bumper will stay where it is giving a 2" gap that you cant do anything about!
      I'd give some serious thought about what you wanna do with it mate! Ive had mine on 265/75/16s since i got it! Ive fitted a 2" lift and ive got the parts sat behind for the next 2" because its just not quite enough for me personally.. I just dont want you to fork out £500ish for BFGs an then a week later think "i want bigger"
      • #18
        2) 265/75/15
        3) 31/12.5/16
        4) 31/12.5/15
        Cheers Taz
        This is what you need!
        http://www.miata.net/garage/tirecalc.html
        • #19
          Cheers Rod
          Heres some piccies
          Cheers Taz
          You could fit 33" tyres on as is. You'll need to remove the side steps or trim an inch or two off the rear end of them as the rear tyres may just catch.
          p.s. That LSPV bracket looks about an inch too high to me.
