handbrake light
  • handbrake light
    hi guys little problem hand brake light will not go off when hand braked is released can yous help.
    cheers thomas.
    cheers thomas.
    checked for Low brake fluid ?
      If the fluid level is OK then the float switch is probably stuck. Just tap the side of the reservoir.
        hand brake
        cheers guys will have a go.
        vheers thomas.
          glad i read this i was about to post the same question, mine goes dim when i take off the handbrake!! the fist thing i checked was the fluid will go and knock the float now!!!
