Hello again.
At what point should the expansion tank start filling with water? I just got back from a short journey, the temp guage had just reached the normal, just below half, point on the guage, and as I was topping up my window washer fluid I noticed that the water level in the expansion tank was above the max level (It's at max when engine cold.) The top of the radiator felt cool on the left side and only slightly warmer near the top hose. The top hose, bottom hose and all the hoses to the heater matrix were all warm to the touch. I'm pretty sure there are no air locks in the system as I've been running it with heaters working fine and no change in the coolant level for weeks. I did put the aircon on for the first time in a while a couple of days ago. Could that cause an air lock? Could it be a dodgy thermostat?
Simon
Simon
