3ltr into 2.4? Ommegawd
  • 3ltr into 2.4? Ommegawd
    I have just discovered this site. The guy is trying to create a bible of all things mechanical on any of the Surfs.
    There are pictures on there of what is required to drop the 3lt engine into a 2.4. I suddenly feel sooooo happy and contented with my 2.4.....
    http://toyotasurf.asn.au/techsite/enginetrans.htm
    Rob G
    i wonder who put this on here as well
    http://www.showmesome.info/hilux/workshop/coolant.htm
      Thats nothing, I've been following a Toyota 3.4 V6 into a 2nd gen in the states, much more fun.
        If he hadn't drunk so much beer he would have gone out and bought a new truck!
          Nah, thats nowhere near enough beer to be tackling a job like that. There's probably a crate in the boot.
            2.4 To 3.0litre
            Hi Folks,
            lts not just the engine to be changed here is a list of some of the problems l have come across changing 2 "2.4" to "3.0litre".
            1/ Gearbox
            2/ Radiator
            3/ Exhaust Front pipe at least if not the whole exhaust
            4/ Water pipes to rear heater
            5/ Power steering pipes
            6/ Air con pump
            7/ E C U has to changed
            8/ The Complete under bonnet wiring loom is needed
            9/ Most if not all the behind the dash wiring loom needed
            10/ Engine mounts on Chassis have to be moved
            11/ Vaccum pipes have to altered "made longer"
            l think it would be fair to say you would need a complete front end of a write off 3.0ltre to do the job.
            Live Life To The Full
              Originally posted by Hilux
              Hi Folks,
              1/ Gearbox
              2/ Radiator
              6/ Air con pump
              i think that says it all bob, FORGET IT, if you want a 3.0 buy one
              [size=5][/size]
                Originally posted by rich
                looks like a 'run of the mill' radio change on a Toyota
                  if he's going to all that trouble... why's he only putting a 3litre in?
