lower suspension ball joint
    Originally posted by NiftyNev
    Yeah, sorry mate thought you were still talking about the ball joint stud. Just undo the remaining nuts.
    Not sure about your part numbers though. Post Model and Frame numbers and I'll double check for you.
    cheers nev, i was confused as to which bit it had failed on, i was concentrating on the other one then noticed this was loose so rung the garage to check.
    mine is cat code 671150, model LN130-GKPGT, Frame no is LN130-0056828, the UK hilux i was cross referencing to is cat code 672560, model LN165-PRMDXW
    =SOLD UP!=
      This is the diagram I get using your Model and Frame numbers. Can't see nuts and bolts for lower joint in the diagram.
      Ball joint is 43340-39245 LH and 43330-39265 RH
        OK Found the 90119-10832 on the diagram but not the other yet.
          couldn't see them on the surf one either but checked the balljoint part number on the roughtrax site, same part as the mk4 pickup on their site then loaded up the pickup details in the EPC so i'm hoping the rest of the suspensions the same
          =SOLD UP!=
