Is it possible to just remove the glass from the sunroof without removing the whole unit? From what I can see through the small gap around the roof lining it looks like the glass is held in position by brackets screwed into the main assembly. I need to replace the glass but don't want to start stripping everything out only to find you have to replace the whole unit.
As usual any help would be greatly appreciated.
