I have currently got an A02A rear axle on my 3rd Gen Surf, which suffers from having Rear Drum brakes....
I have also sourced a full Toyota Landcruiser rear axle with disc brakes, which should fit perfectly, apart from one problem.....the rear diff ratio is 4.3:1 (LSD / manual locker - not sure of the code), whereas my A02A is a 4.1:1 ratio.
My first thought was to just swap the half shafts / hubs into my axle.....only the backplate has slightly different bolt centres....
My second option was to swap my 4.1:1 diff into the Landcruiser axle and install the complete unit....only my axle / diff casing (open diff) bolts are regular spacings and the LSD / Locker Diff has one side altered to suit the locker.
Does anyone know if the studs in the axle housing are drilled to suit various diffs, so that when you install open diff the regular holes are used and when Lockers installed, intermediate holes are used?
I cannot find a diagram of a Toy LSD / Locker Diff Casing anywhere to see if I can fit my Open Diff onto the axle housing without modification (drilling and tapping)
Anyone want a 4.3:1 axle with lockers, LSD and Rear Discs?
Damon
Damon
