hi there im having problems removing the nut on the crankshaft pully what makes it harder is that i cant lock the wheel with anything because the woodruff key has gone so the pully is just spinning on the shaft this i need to remove it to fit a new key i read somewere on here that if i put a spanner on the nut the locked it against something that i could turn the engine over and this would loosen the nut not sure if this is a good idea i dont want to do anymore damage to the engine any ideas i would be greatfull need to get my machine back on the road
thanks
mick
thanks
mick
