Injector Clean????
  • Injector Clean????
    Gday Guys,
    Is It Possible To Clean The Injectors Yourself? If So Could Somebody Tell Me The Way To Go About It.
    BRING ON THE MUD!!!!!
    Dump a whole bottle of Redex Diesel Treatment, or similar, in the tank next time you fill up and give it a bit of welly. The injectors will clean up a treat mate.
    Welcome to the forum.
    It's only a hobby!
      Thanks Mate For The Advice And Welcoming Me. Do You Know If Redex Is Sold In Australia Or Should I Just Ask For A Diesel Fuel Aditive For Its Injectors
        Gday Blue
        WELCOME
        Redex is available world wide but if you can get it as for a strong system cleaner as you bet the whole system needs cleaning.
        Oh and by the way I wasn't taking the p**s with subject section.
        Be lucky and happy surfing mate.
        One more thing if you are due a filter change half fill the filter with cleaner top up with deisel then start and run at about 2k revs for 5/10 mins, make sure your engine is warmed up before you do this, much kinder on the engine and easier to start.
        check oil level before as well top up as required.
        Paul.
          Put the whole bottle in to 1/4 tank of fuel, works best
          My 4x4
          My choice
          Back off
