ok i just noticed that the rear axle on stein is about an 1 1/2"to far over to the offside.compared to the nearside how do i pull it back into correct alignment.
rear axle alignment.
It did the trick for me
. I found that putting the drop bracket on did improve the panhard rod angle but made the axle alignment worse. The adjustment in the rod allows you to pull everything central again.
Roger
I FOUND THE OWNERS THREAD http://www.yotatech.com/showthread.php?t=74915(\__/)
just read the whole of that thread.wow,what a build up.nice find marky.Originally posted by markyI FOUND THE OWNERS THREAD http://www.yotatech.com/showthread.php?t=74915www.overfab.uk
found it http://www.yotatech.com/showthread.php?t=57254
You owe me a PINT :deal2
Another cage :http://www.cardomain.com/ride/2303256Last edited by marky; 30 March 2007, 21:57.(\__/)
