Is it possible to have the brake compensator linkage pipe re-shaped as I now tow a caravan and when all hooked up the exhaust seems to be only millimetres away. I imagine that it must make contact when moving over uneven ground. I am unable to move the exhaust any higher as it would then interfere with the towbar frame. If this is possible what does it entail work and cost wise.
Brake linkage under exhaust.
