coolent bleed valve
  • coolent bleed valve
    Ive seen on some of your beast you have a bleed valve added to the coolent circuit on the hoses going into the bulkhead.
    Can anybody give me a shopping list so I can create one for my beast ready for it to go back on the road?
    I saw that thread. Why did I struggle taking my bottom hose orf when there is a drain valve. Well the ****** air-con rad is in the way and you can't see it anyway.
    73 OM
    It's only a hobby!
      Phil
      The bit iam refering to is for burping the system when filling it up to prevnt air locks....
        73 OM
        the rad drain plug is accessable when you take the bashplate off
          It's also accessible if you have relatively small arms through a gap at the bottom of the passenger side wheelarch.
            I ended up manufacturing a tool to spin the bottom hose clamps round, so the clips would face the top..............aaaaaaaarrrgh hhhhhhhhh!
            I guess I'll know next time
            It's only a hobby!
