Here's my 1996 3rd Generation Hi-lux Surf. It is acquired from Japan and we use it now in the Philippines. So it is technically a Right Hand Drive converted into a Left Hand Drive vehicle. Everything worked fine except this one problem that's bothering us for months now.
My problem is:
1. The conversion of the steering posted some problems. The power steering was inverted in order to accommodate the inversion of the steering wheel from right to left. So the power steering bracket was re fabricated and refitted.
2. The power steering lines (e.g. steering fluid lines) got snagged in the front axle (remember: RHD to LHD conversion) so we have to lower the power steering by about 2-3 inches.
3. And so another problem occurs. As we lowered the power steering the the angle of the steering joint was way off line. see picture:
To anyone out there who encountered similar problems please feel free to input your suggestions. Any suggestion and tips will be much appreciated.
that's all for now. thanks everyone!
p.s. Will continue to post once i got to take a picture of the other related problems.
My problem is:
