On the instruments dash it is showning a T Belt sign
can somebody help me with this ? please
Fist of all we need to know what vehicle you have.Fill in your profile with surf details.
Has the timing belt been changed do you know.If not then i would get it changed.If you have a 2nd gen then in the bottom centre of the dash panel you will see a rubber grommit,take that out and using a cocktail stick or something put thru the hole and you will see the reset button for the timing belt just press that
