cv joint
  • cv joint
    how hard is it to change the front cv joint could i do it myself or is it a garage job 1992 ln130 ideas on the procedure would be helpfull
    thanks
    mick
    http://www.toyotasurf.asn.au/techsite/cvjoints.htm
      thanks
      mick
      depends how much you like to wear grease, and getting the shaft out if you've upgraded your suspension is a bit h. Personally after changing a gaiter I would seriously consider a garage, and then probably end up doing it myself.
      Gone from 4x4 to 1x2
        cv joint
        cheers fellas very helpfull
