VSV 6 should have a small black canister shaped filter on it. Do not connect to vacuum or cap it. Look at your other VSVs and you will see what they look like providing they are not missing as well. You can always make a filter from a small plastic fuel filter stuffed with some cotton wool and connect via a piece of vacuum hose. This end of the VSVs is open to atmosphere to allow air to pass in and out of the plunger end of the VSV. The T on the turbo pressure sensor line is for the boost gauge.
Nev
Nev
unless you rev the arse off of it in 3rd...once you change in to 4th the revs just seem to either just about hold on the flat...pick up a bit down a hill or drop off uphill!....never even got as far as 5th!...oh...and to add insult to injury the speedo just packed up!...it was wobbly before so suspect the cable has snapped or something
