Can anyone tell me what size of bolt I need to remove the rear drum please?
Rear drum removal...
there are 2 threaded holes in the drum that allow you to push the drum off, if its stuck. but i cant remember what size they are.. (smacking the drum with a mallet helps as well..)Originally posted by BUSHWHACKERBolt??????
It should pull off if the handbrake has been released.it's in me shed, mate.
here u go DamianOriginally posted by DamianCan anyone tell me what size of bolt I need to remove the rear drum please?
http://www.yotasurf.co.uk/forums/sho...30&postcount=1Gaz
It isn't too late and cheers for the info Gaz, however I suspect that the bearing has gone south. I took the wheel off and turned the drum, I could feel the rumbling through the drum, it was very notchy (or is that knotchy?)
Whilst under there I greased all the nipples I could find, the front front UJ took absolute loads.... oooops!
I'll go out tomorrow and buy some HT M8 bolts and have a look at both drums, 'cos you never know!
Thanks again all!Damian
http://www.themudlife.co.uk
