Hi all, can anyone help or point me towards any posts or pics of a drivers door window mechanism. I have an electric window which seems loose in its mounting and rattles if you drive with it anything other than completely open. Aside from that it goes up and down fine and I would like to try and sort it while I am on my hols before it becomes an expensive repair job. btw its a 1994 ssrx 3.0 turbo diesel. Cheers in advance guys.
Drivers window mechanism
If the mech is lose in it fixings its simply bolted in place by 4 x 10mm (they are visile when the door card is removed (about where you would expect the manual windy handle would be)...there bolts the are an additional 2 bolts at about the same hight but towards the middle of the door that form part of the pivot part...if its not these the only thing left is where the mech joins the bottom of the window (again 10mm)Originally posted by phil1234Hi all, can anyone help or point me towards any posts or pics of a drivers door window mechanism. I have an electric window which seems loose in its mounting and rattles if you drive with it anything other than completely open. Aside from that it goes up and down fine and I would like to try and sort it while I am on my hols before it becomes an expensive repair job. btw its a 1994 ssrx 3.0 turbo diesel. Cheers in advance guys.
if you arm yourself with a philips screw driver to get the door handle and the open handle off..and then a 10mm socket to tighten the window fixings.
hope this helps..
Ssparkz
http://www.elite4x4.co.uk/
hope this helps..
Ssparkz
