does anybody know if you can fit the landcruiser 2.4td manual gearbox to the 2.4td auto surf engine or are the splines different????????
lancruiser/surf
Surf has the W or G type tranny whilest LC use the R series. If you have the stock LC bellhouse than it will fit.
The splines are in the clutch plate, which an auto doesn't have, so you need the flywheel and complete LC clutch too. Maybe even the starter, but I'm not sure on that.
Don't forget that a LC has both drive shafts on the right, your drivers side, while the Surf has the rear one in the middle. So you need to move the fuel tank and run a LC rear axle too.
Hello Roger - I see you have the supra 3.0 engine in your truck along with some other nice axle goodies.Originally posted by eurorunnerDon't forget that a LC has both drive shafts on the right, your drivers side, while the Surf has the rear one in the middle. So you need to move the fuel tank and run a LC rear axle too.
Post some pics - I think you'll have to post an internet link - photobucket or something like it.
regardsAnother member of the 'A' team
