Hi Guys
My 94 3.0t SSR-X has a wobbly front diff and I wondered if you could help.
It drives fine, goes in and out of 4 wheel drive fine and does off road stuff fine.
I was under it about 3 months and 5000k ago and whilst having a prod around found that by hanging in the drivers side front drive shaft, I could rattle it around with about 3mm movement on the output shaft from the diff. I had previously noticed a slight rattle from the front on potholes etc but thought it was front brake pad rattle.
Its at the garage today getting a service and I asked the guy to look at it. His view was that it was probably a bearing.
With your vast collective knowledge, has anyone had similar, how far will it go until it explodes (does it turn over when in 2 wheel drive), how much, and anyone got a good spare?
Thanks
Thanks
