K & N air fliters
  • K & N air fliters
    Hi all, when I get me surf back from the mechs hopefully with new head and all working great, I was thinking of getting a little more ooomph.
    I know about the waste gate mods etc, but was wondering whether a K & N air filter woud increase horse power on a diesel?
    Anybody know for sure, and if so how much extra power??
    Rob
    Still working for the man!
    Don't.
      Originally posted by MattF
      Don't.
      yea dont do it.(see matt your opinion is appreciated)
      www.overfab.uk
        And I didn't bother preaching this time 'cos I thought no one would listen.
        Damn.
          Damn.
          please preach tell us more!
          colin
            I have a K &N on the Bullet - not noticed any more ummphhhh, but it makes a lovely rumble
            Tip - fabricate a box or some soundproofing for it though or it whistles like mad!!
            Linda
            www.4x4toys.co.uk
              colin
              Oh well. If one must.
              The performance filters work by reducing the restriction on the air intake,
              which is how they increase HP by some degree. However, they reduce the
              restriction by filtering less crud out of the airflow. The particulate filtering
              ability is less than the stock filter. You get power at the cost of larger pieces
              of dust and debris entering your engine air intake. The filters were designed
              for racing team purposes, where the engines are completely stripped and
              rebuilt, or even replaced, on a regular basis, usually only several races. A far
              better method would be to simply make a less restrictive intake for the
              standard air filter housing, without the noise deadening baffles. You would
              get increased air intake whilst retaining the full filtering abilities of the stock
              filter. The performance filters are detrimental to engine longevity. How much,
              it's hard to say.
                Removing the intake baffles can achieve the same growl.
                  Awh well - I guess when the engine dies we'll just bung in a spare one then, for now I like the rumble.
                  Linda
                  www.4x4toys.co.uk
                    Hmmm but the K&N was a pressies from MrT to his LAdy friend the Bullet so 'twould be wrong not to use it....
                    Linda
                    www.4x4toys.co.uk
                      Must admit, you need not worry like most of us about your engine going
                      bang. Well, apart from the mechanic taking his time to get it sorted.
                        Thanks for the info, I,ll give that a miss then.( although with 100,000 miles already engine wear is a mute point)
                        BTW, where are these baffles that need to be removed??
                        Rob
                          The piping that goes from the air filter housing to the front of the Surf.
                            disconnect the flexi pipe 90 degree bit from the intake leave it connected to the airbox but turn it round 180
                            =SOLD UP!=
                              Do you happen to have a photo of that mod you would be able to post please?
                              I quite fancy doing it but are there problems with the car running hotter if it's sucking air from the engine bay?
