auto box
  • auto box
    hello everyone
    i have just bought my surf 2.4 1991 ssrx.and i would like to go through it -oil changes and the like,i have had cam belt changed,i would like to change oil and filter in auto box,i have tried local gararges and no one wants to do auto boxes,has anyone found any problems in doing this themselves,i have haynes manual and it seems a strightforward job but maybe i am missing something,box is working ok but oil looks a little on brown side
    cheers
    bob
    My ATF did not look too bad so I simply dropped the sump cover off the gearbox catching the fluid as best i could. Did not change the filter but filled up with new ATF.
    It would seem that they do not expect it to need changing so make no simple provision for doing so.
    Keith
      Originally posted by bonehead
      hello everyone
      cheers
      bob
      i know some on here have changed the autobox oil, just found this on a site....
      As an import I thought I'd change all of the fluids inc . the auto trans fluid. However, having purchased the filter and gasket I now find that all the auto specialist I've contacted say "Don't do it!". They say that the damage that can be caused to the seals etc when doing a fluid change isn't worth risking and that I should just keep it topped up.
      [size=5][/size]
        auto box
        thanks for replys everyone,it would appear it is leave well enough alone,its working ok now,i will leave the oil in the shed.
        cheers
        bob.
          cheers
          bob.
          if you do fancy doing it the info is here, http://homepage.ntlworld.com/dorothy...bemx/p_m20.htm
          [size=5][/size]
