I did try the daemon tools bot couldn't get that to work either, gonna give up soon i think, spending a lot of time on it, just gonna try CDR first then give up.
Thanks for all the help though guys.
------------------------------------------------------------------- [FONT=times new roman][/FONT][COLOR=red][I][B]1994 SSR X LTD 3.0[/B][/I][/COLOR]
I think the main problem that you are having is the size of your hard disk.
EPC is an old program that can't correctly work with hard drives above 999MB so you need to make a 1 gb or less partition on the Hard disk (even if you are running it from the CD) otherwise it doesn't install correctly.
Once you do this and reinstall it works OK - mine did for all the disks (Euro 1 & 2 and Japan 1 & 2).
