wee bit o help got a 710 leak from the near side off the engine it aint comming fi the head it seems to be getting the back o the engine. along left side off the bellhouseing dropping down onto the prop
dont know if it may be fuel or not hope some o you peeps can give me some advice thanks the hilux is running well an i have no other problems
o,what size is the socket to fit the plug to check the diff leval thank ,bun
