my turbo packed in the other day something about the waste gate not sure of any other details. does any one know were to pick up a 2nd hand one at a good price.
Turbo
It may be just the wastegate diaphram that needs replacing, as there isn't much to go wrong with the turbo. As long as it spins freely and no graunchy noises it's fine.
The Turbo is a CT20, if you're searching for spares.
TonyN may have one other than that, there's usually some on Ebay.
Also, check the rubber pipe (the red one in the diagram) is attatched and not come off or split before condeming the turbo diaphram.Last edited by BUSHWHACKER; 3 November 2006, 14:25.
I've used these guys they're pretty goodOriginally posted by benyetinyahoo
http://www.thorntonbreakers.co.uk/Another member of the 'A' team
Bushwacker -
sorry still gettin used these threads and that lol right when i took it to the garage they said between the turbo and dump valve is a waste gate and that has broken not sure how bad it is there is no harsh sounds coming from the turbo thats all i know i'm a bit mechanicly minded but only to a certain point i'm learning some thing new every day thanks alot ben
It's just the wastegate part you need then, as there is a spring and a diaphram in there. Either the diaphram is split or the acuator spring is really weak they control the boost pressure the turbo creates.
You can get a second hand turbo for around 80 quid.
Not in the wastegate itself. The wastegate actuator has these bits. Sometimes the wastegate housing or wastegate itself can crack. This is where the rod from actuator connects to.Originally posted by BUSHWHACKERIt's just the wastegate part you need then, as there is a spring and a diaphram in there.
Nev
